Activity › Forums › Adobe Premiere Pro › RAM for CS – 24, 32 or 40GB?
Posted by Bob Woodhead on July 13, 2011 at 2:46 amIn the continued quest to switch over to CS5.5, figure it’s time to upgrade the RAM in my MacPro early 2009 (quad core).
Debating: 24GB $200, 32GB $400, 40GB $660 (the 24 & 40GB options use the 4x2GB already installed).
Any reason I shouldn’t just go for the 40GB? CS5.5 & Snow Leopard (Lion eventually) will use ALL of it, yes? I enjoy having PS, AFX, PPro, Audition (and of course all the “daily apps”) open at the same time.
Sam Parnell replied 14 years, 9 months ago 6 Members · 8 Replies -
Todd Kopriva
July 13, 2011 at 3:10 amWe recommend 4GB installed per core (counting virtual cores from hyperthreading). For you, that’s 8 cores x 4GB = 32GB.
40GB would be a bit of overkill.
See this page for information about memory and performance in After Effects: https://bit.ly/dC0MdR
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Nevin Styre
July 14, 2011 at 4:00 amDoesn’t the quad core Mac Pro only have 4 ram slots? I don’t think you’ll be able to use your old ram for 40GB config, I think 32GB is the max with 4x8GB.
Bob Woodhead
July 14, 2011 at 12:39 pmThank you Todd. But I realized I made a mistake in my system specs! I’ve got the 8-core, dual CPU, hence After Effects showing 16 CPUs. So by that math, 64GB is my sweet spot.
I’ll make it a 2 step upgrade; 4x8GB now, and then replace the current 4x2GB with 4x8GB later in the year.
“Constituo, ergo sum”
Bob Woodhead / Atlanta
Quantel-Avid-FCP-3D-AFX-Crayola
Panasonic HPX500/AF100 -
Todd Kopriva
July 14, 2011 at 3:36 pmWe’ve found that there isn’t an appreciable performance increase using more than 8-10 rendering processes. We have a machine with 96GB of RAM, and it doesn’t out-perform the one with 48GB of RAM. I think that money spent on RAM over ~48GB of RAM is wasted if you’re just concerned about After Effects.
(With 48GB of RAM, leaving 1/3 of RAM for other applications, you have enough for 4GB of RAM for each of 8 rendering processes.)
At a certain point, overhead of scheduling processing among various processes et cetera starts to lead to diminishing returns.
Walter Soyka
July 14, 2011 at 3:46 pmDo you have a sense from your tests of how hyperthreading compares to physical processing cores?
More specifically, if you’re only aiming for 8-10 rendering processes, is there a substantial difference between a machine with a single 6-core processor or dual 6-core processors?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Todd Kopriva
July 14, 2011 at 4:04 pmThe dual-six is certainly going to be faster than the single-six. Even when you’re only running _one_ rendering process, After Effects will spread threads to all CPUs (both virtual/logical and physical).
In this video, I show that all CPUs are used even when running without Render Multiple Frames Simultaneously multiprocessing:
https://www.video2brain.com/en/videos-5355.htm———————————————————————————————————
Sam Parnell
November 22, 2011 at 11:19 pmBob, I was searching forums for info on PPro RAM. Where are you looking to buy RAM for those prices?? Everywhere I am seeing, 8gb is about $300.
sam
