Activity Forums Apple Final Cut Pro Legacy Ram and other performance upgrades to MacPro
  • Ram and other performance upgrades to MacPro
    Posted by Oscar Brightman on September 20, 2010 at 6:53 pm
    Hello,
    I have a MacPro1,1 Dual-Core Intel Xeon 2.66 GHz that I would like to upgrade for better performance and I am told the simplest way is to upgrade the RAM. Currently I have 3GB (2×512 and 2 x 1GB). I am wondering if I buy another 4GB (2 x 2GB) will that work okay even though they are different size configurations? In other words, can they all play together nice to make 7GB of memory or do I bite the bullet and pay double for 8GB of Ram (2x4GB or 4 x 2GB)? Obviously I would prefer the cheaper option if it will work.
    Also, beyond ram, what would be the next two upgrades you would recommend for better performance editing and effects processing (Motion, After Effects, FCP 6).
    Many thanks for your comments!
    Oscar
    Jeff Mueller replied 16 years ago 4 Members · 3 Replies
  • Scott Sheriff
    September 20, 2010 at 7:14 pm
    “Also, beyond ram, what would be the next two upgrades you would recommend for better performance editing and effects processing (Motion, After Effects, FCP 6).”
    Bigger, faster processors.
    Scott Sheriff
    Director
    SST Digital Media
    https://www.sstdigitalmedia.com
  • Shane Ross
    September 20, 2010 at 7:17 pm
    Motion likes beefy Graphics cards. ATI 4870 for example…but that’s an older one. I’m sure there are newer models. Make sure you get the MAC version…
    Shane
  • Jeff Mueller
    September 21, 2010 at 3:07 am
    I’m running basically the same system, but have gone from 3 up to 6 GB of Ram and have an ATI 4870 that I just need to flash.
    More than 3 GB of Ram is definitely helpful, most here say 8 GB minimum, 12-16 GB ideal, but it does depend on what programs you’re using as to how much beyond 4 (always need more than 4) you really need. My understanding is that AE loves Ram, Color is mostly dependent on the GPU except when rendering, FCP mostly wants really fast connection to the media. And yes you can (and should) keep your current Ram. With your Mac you MUST use matched pairs, that is, always have 2 exact modules, meaning not only same size but same manufacturer and production run. However, the idea that you need 4 of a kind is bunk. In certain circumstances there is a very slight performance bump to having 4 of a kind, but it is nowhere near equal to having more Ram, So 8 GB would be great but really you should do 4 x 2 GB and still add your 3 GB to the mix for 11 GB, or if you can’t afford that now, do 2 x 2GB to get to 7 and plan on adding another 2 x 2 later.
    I’m not a Computer expert, but I have researched this extensively for myself. Good luck.
    Jeff Mueller
    http://www.ApertureVideos.com
    Santa Barbara, CA
