Activity Forums VEGAS Pro raising the volume of only part of the soundtrack
  • raising the volume of only part of the soundtrack
    Posted by Philippe Orlando on October 22, 2008 at 4:46 pm
    Hello,
    I know how to raise the whole audio track volume, but can I choose which part of the track I want to raise?
    Until now I’ve been using different audio track each time I needed different level, but it’s going to give me too many tracks. So is there a way to select part of a track and only raise or lower the selection?
    Phil
    Philippe Orlando replied 17 years, 10 months ago 2 Members · 2 Replies
  • John Rofrano
    October 22, 2008 at 6:58 pm
    Highlight the audio track and type the V key to display the Volume envelope. Then just double-click on it to add a keyframe anywhere that you need to change the volume (…you can also right-click and select Insert/Remove Envelope > Volume (Shift+V))
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Philippe Orlando
    October 27, 2008 at 8:03 pm
    Thanks a lot John, it worked great
    Phil
