Activity › Forums › Apple Final Cut Pro › Raise volume plug in
Posted by Roger Sherman on September 29, 2021 at 4:17 pmIs there a plug in or work around where I can raise the volume above FCPX +12db?
Roger Sherman replied 4 years, 11 months ago 3 Members · 5 Replies -
John Fishback
September 29, 2021 at 4:37 pmIn Audio > Effects > Levels there’s an effect called Gain which should do what you want.
Roger Sherman
September 29, 2021 at 6:05 pmAm I looking in the right place? Audio mode where Volume, Audio Enhancements Pan are located? Below Mode/Stereo is Effects. There’s a box that needs to be checked but it will not. And, No Effects Applied.
Or is there another place?
thanks.
Jeremy Garchow
September 29, 2021 at 6:17 pmYou have to open the audio effects panel and apply the effect.
Command-5 should show/hide the effects panel.
