Activity Forums VEGAS Pro Raining Continuous Text
  • Raining Continuous Text
    Posted by Clay Dempsey on January 31, 2007 at 5:18 pm
    We are working on a project where we have been asked to ad the comments about the product to the end of the video. Instead of one comment at a time, we are suppossed to lay them over one another and have them fall like rain continuously for a few seconds. Is there any tutorial on this or any insight on where to begin?
    Terry Esslinger replied 19 years, 7 months ago 2 Members · 3 Replies
  • Terry Esslinger
    January 31, 2007 at 7:50 pm
    One way might be to put each comment (generated text?) on a separate track above everything else and use track motion and keyframes and let the rain fall:).
  • Clay Dempsey
    January 31, 2007 at 8:08 pm
    I will try this out when I get home. I’m kind of new to extensive video editing. The background will be black, can you go into more detail what you mean by separte track? And will I be able to make this flow continuously, like when the text reaches the bottom it then starts back falling from the top?
  • Terry Esslinger
    February 1, 2007 at 2:22 am
    If you are not putting it over a video then you just create a text generated media. The background will appear black but it is actually transparent so that if you put video on a track below the text track you would see the text over the top of the video.
    Write your text. Then go to track motion and set a keyframe with the text in the starting position (above the screen if you want). Then set a second keframe with the text at the bottom (on the ground :)) When you play this the text will move from the top to the bottom over the period of the keyframe. You want another text item ‘falling’ at the same time but at a different rate?? Make another generated text and place it on a separate track above the first and make it either longer or shorter than the first one. Then place keyframes in the track motion with the first one above the screen and the last one ‘on the ground (or below if you want)You just keep building this pyramid with as many text events as you want. Except if you have the ‘lite’ studio version of Vegas you are limited to 4 video tracks – the full version is basically unlimited.
    If you have more questions I can email you a .veg file example to look at.
