Activity Forums Adobe After Effects Raining Characters In
  • Raining Characters In
    Posted by Joshua Earles-bennett on May 2, 2006 at 2:09 pm
    How do you adjust the time on this thing? I have a 3 second comp and applied the animation and it runs the 3 seconds of the comp, but when I reduce the comp length it doesn’t change the animations time. I’ve tried the different settings, but it seems to stop the animation instead of speeding it up.
    Erick Ransom replied 15 years, 6 months ago 3 Members · 3 Replies
  • Sam Moulton
    May 2, 2006 at 3:08 pm
    press the u key to show the keyframes, you should see two. then adjust the keyframes
  • Joshua Earles-bennett
    May 2, 2006 at 3:11 pm
    Thank you that worked. It turns out the other keyframe was outside the comp length. Got it working.
  • Erick Ransom
    March 8, 2011 at 12:19 am
    Where can i download this preset?
