Activity › Forums › Adobe After Effects › Rain Effect
Rain Effect
Posted by Christofer on December 2, 2005 at 3:32 pmftp://ftp.idsoftware.com/idstuff/wolf/rtcwolfenstein_trailer.zip
I would like to achive this effect (intro part), is it possible with using only AE6.5, is there any plugin that can do it eazily and last part of this question, would it be more eazy to do it with motion 2? (But still, can i do it with AE)
Thanks for your answer
Andrew Yoole replied 20 years, 9 months ago 7 Members · 10 Replies -
Christofer
December 2, 2005 at 3:36 pma better adress is https://games.activision.com/games/wolfenstein/t1.html
Jim Zito
December 2, 2005 at 4:08 pmHmm. I would try to do it for real. It doesn’t look that hard. You could probably do it on a relatively small scale. It doens’t have to be long either, because you could loop it. Then use a blending mode for the bluish color.
HTH
Jim -
Christofer
December 2, 2005 at 4:52 pmAhh i was thinking about that first but then i come to my small problem.. i dont realy have the luxary of doing it in real, i have about -20C outside and no real place to set up indoors.. But most of all, can it be done with AE?
Yussef Cole
December 2, 2005 at 5:43 pmWell you can definitely use a particle system for the rain. The ground reflecting the rain however would be mighty hard. If anything, you’ll need a 3D app for that one. Maybe you can do it in your bathroom on some plastic sheets or something. Seriously sometimes real life cannot be replaced by simulation.
btw, the voice acting in this game??
your..reign…of….terror…must end.
you know… as well as i… do that i….cannot be destroyed!
almost as bad as the first resident evil!
Rob Kahn
December 2, 2005 at 6:32 pmYou can get an approximation with a combination of Foam and blending modes.
Jim Zito
December 2, 2005 at 6:34 pmHa! Yeah I have that Wolfenstein game. The acting is really bad. The German soldiers say the dumbest things and their accents are ridiculously exaggerated.
Fun game though.
Holly
December 2, 2005 at 11:01 pmI just started learning Apple’s Motion last week… and I’m almost positive there are a few easy setup rain filters in that one.. Maybe you can try and get a hold of that program?
Christofer
December 3, 2005 at 9:07 amAhh thanks alot, yeah i have the taril verion and have placed an order for the full version.. Thanks for the ide with the foam and everything, but as i said before, to get hold of a camera that can shoot in such a high framrate that accually make the rain look good in the shower, i
Thehardmenpath
December 3, 2005 at 8:26 pmPerhaps Water World and Caustics filters combined on the same layer could do the trick.
Andrew Yoole
December 4, 2005 at 7:40 amIf you have the budget, Artbeats have at least 2 clips almost identical to this – WE211H and UW117
