Activity › Forums › Adobe After Effects › rain drops
rain drops
Posted by Ben Peterson on November 25, 2018 at 2:01 amWhat would be the best way to make light raindrops on water effect?
Ben Peterson replied 7 years, 8 months ago 2 Members · 2 Replies -
Kalleheikki Kannisto
November 25, 2018 at 9:25 amI’ve successfully utilized Radio waves as an animated texture for Particular for such. Result can be used to drive displacement, glass or other similar effect, depending on how realistic a result you are after. Works great as a bump map converted to normal map for Element, for instance.
Senior Graphic Designer -
Ben Peterson
November 30, 2018 at 9:08 amHey Kalleheikki, Sounds complicated. Any tut you know of anywhere? Or if you have time could you please explain more in length? thanks
