  • Posted by Thomas Morter-laing on March 7, 2011 at 10:36 am
    Im working at a company at the moment who uses an 8TB NAS RAID. It is RAID 6. (We are a video editing company). The data on the RAID is very important, which is why I think they originally went with RAID (for the parity striping etc). However, will this slow everything down> Just reading up about RAID 6 and it apparently doesn’t offer that many advantages, but DOES slow the system down a fair bit because if the amount of algorithms RAID6 needs. What would you guys suggest is the best for an 8TB (8 HDDs) RAID for video editing?
    Tom Morter-Laing
    Freelance Editor
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
    Rafael Amador replied 15 years, 6 months ago 5 Members · 6 Replies
  • Jeff Greenberg
    March 7, 2011 at 11:26 am
    It’s essentially identical to a RAID 5, but with greater fault protection – two drives can die, rather than one.
    Does it slow it down over Raid 5? yup. Does it provide a higher level of protection for –[Thomas Morter-Laing] “The data on the RAID is very important” – also yes.
    I’d sleep better at nights with a Raid 5…and really well when it’s a raid 6.
    Of course, if the speed hit worries you, you could always measure the speed of the drive to see if it’s significant with your editorial format of choice.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • David Roth weiss
    March 7, 2011 at 1:29 pm
    It’s not the Raid 6 configuration that’s the problem Thomas, it’s the fact that it’s NAS (network attached storage). The vast majority of NAS Raids are not fast enough and not suitable for video editing, they are primarily designed to provide safe and inexpensive system-wide backup for general office use. Unless the NAS setup is very fast, or designed soecifically for video editing, the odds of it providing enough throughput for editing even DV would be questionable.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Paul Jay
    March 7, 2011 at 4:47 pm
    iScsi protocol on ethernet works very good with editing, but most NAS systems don’t work good indeed.
    RAID 6 is great, because 2 drives can die, but any RAID can burn down from fire or fall of a table.
    You need Backup/archive on 2 physical locations.
  • Rafael Amador
    March 8, 2011 at 2:49 am
    To put everything in a device, whatever the protection may have, is CRAZY.
    The best solution is RAID 0 and all the media duplicated somewhere else (and not to close).
    rafael
    http://www.nagavideo.com
  • Jeff Greenberg
    March 8, 2011 at 3:36 am
    Is the idea of not backing up (you’ll read everywhere that RAID IS NOT A BACKUP) the crazy part? Then yes.
    But a Raid 6? Raid 5 or 6 (or 5+1 or 5+0) is the basis of pretty much every heavy duty SAN at broadcast networks.
    Best,
    Jeff G
  • Rafael Amador
    March 8, 2011 at 9:16 am
    [Jeff Greenberg] “Is the idea of not backing up (you’ll read everywhere that RAID IS NOT A BACKUP) the crazy part? Then yes.”
    Hi Jeff,
    Many people consider that having the media on RAIDs that duplicates the files is enough back-up.
    I want my back-ups not just in another machine, but even on another room.
    [Jeff Greenberg] “But a Raid 6? Raid 5 or 6 (or 5+1 or 5+0) is the basis of pretty much every heavy duty SAN at broadcast networks.”
    Sure. That great for big traffic, etc, but for a single editor, RAID-0 is the simplest, the fastest and the cheaper.
    rafael
