Activity Forums Apple Final Cut Pro Legacy Raid0 setup failed
  • Raid0 setup failed
    Posted by Randolph Harrison on December 25, 2006 at 2:08 am
    My first time setting up a raid with disc utility. I have ten drives in two enclosures. When disc utility opens, it shows 20 items…the ten drives by name and below each, the volumns. When I drag all items into the box, it shows twice as much space as there really is. When I have dragged either of the ten items into the box,(name or volumn) it shows the right amount of storage, but when I run the program, it reads “Creating Raid set failed” “Could not add a raid disk to a raid”.??? My settings are “Mac 0SX Extended (no journaling) 32k blocks”
    What am I doing wrong. Thanks for your time…and a very happy holidays to you all.
    Randy
    Randolph Harrison replied 19 years, 8 months ago 2 Members · 2 Replies
  • David Bogie
    December 26, 2006 at 4:04 pm
    Try the OS10 forum on apple.com or here.
    Creating a RAID is not easy and the procedure is full of subtle gotchas. You haven’t included any information about the drives or why you think you want to create the RAID. A 20-drive RAID-0 is, umm, a questionable setup.
    Most of the threads we see about RAIDs are posted by users who are sadly misinformed. This might help:
    https://www.staff.uni-mainz.de/neuffer/scsi/what_is_raid.html
    bogiesan
  • Randolph Harrison
    December 27, 2006 at 7:25 am
    Hi Bogiesan,
    I am cutting a small feature on FCP. It was shot 1080p…about 3 terabytes of info. I have 2 – 5 enclusure burleys with 10 x 500 gig seagates. I’m planning on Raid0 to get the speed I need for the full res feature. I did get the raid to work with disc utility tonight…think I have it figured out. But if you have any other suggestions, they are always greatly appreciated. This is my first attempt.
    Randy
