Activity › Forums › Creative Community Conversations › Raid0 by daisy chaining 4 WDC Thunderbolt MyBooks
  • Steve Connor
    January 26, 2012 at 10:12 pm
    Ooooh!
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
  • Paul Jay
    January 26, 2012 at 10:40 pm
    And if 1 crashes. Bye bye data.
  • Craig Seeman
    January 26, 2012 at 11:08 pm
    You mean you’re not looking forward to the LaCie version?
  • Shane Ross
    January 26, 2012 at 11:45 pm
    Yeah…sorry, RAID 0 is so 5 years ago. Now there are plenty of RAID 5 (protected/fast) options out there that RAID 0 makes no sense. Skip this and get the Promise TB Raid…
    Shane
    Little Frog Post
  • Steve Connor
    January 26, 2012 at 11:53 pm
    Doesn’t the WD Duo do RAID5 across both it’s drives?
    Steve Connor
    “FCPX Agitator”
  • Chris Harlan
    January 27, 2012 at 12:29 am
    Pretty cool.
  • Shane Ross
    January 27, 2012 at 1:27 am
    RAID 5 requires at least 3 drives. Two drive protected RAID is Raid 1. And even if you RAID 0 four drives that are RAID 1, if you lose one of the units, the RAID 0 is broken
    Shane
    Little Frog Post
  • Andrew Kimery
    January 27, 2012 at 7:49 am
    I think it’s pretty crazy seeing those speeds with off-the-shelf gear on an iMac. Practical? Not really. But neither are show cars but that doesn’t mean they aren’t fun to gawk at. Geez, buncha wet blankets up in here. 😉
    -Andrew
    2.9 GHz 8-core (4,1), FCP 7.0.3, 10.6.6
    Blackmagic Multibridge Eclipse (7.9.5)
  • Jeremy Garchow
    January 27, 2012 at 1:25 pm
    You aren’t allowed to be excited about technology anymore, especially anything that has to do with thunderbolt, or anything that’s brand new.
    It’s passé.
    By the way, you could easily set those up raid 1+0 (or raid 10).
    Each my book is raid 1, then raid 0 the whole thing together. If one of the my books loses a drive, simply replace and rebuild. It won’t effect the raid 0 structure of it as the raid 1 protects it. This is actually a very secure way to work due to the amount of redundancy. Won’t be the fastest, though.
    Jeremy
  • Jeremy Garchow
    January 27, 2012 at 1:33 pm
    I should add that raid1 halves your total capacity.
    If each one of those my books has 6TB total, the capacity will be 3TB after the raid1 set.
    The 24TB shown would be 12 TB protected.
    Jeremy
Page 1 of 3
