Activity › Forums › Apple Final Cut Pro Legacy › RAID troubles; erased, won’t behave now.
  • RAID troubles; erased, won’t behave now.
    Posted by Mark Suszko on September 4, 2013 at 1:42 pm
    I used disk utility to erase my RAID drive as part of an overall system clean-up. Took 3 days to zero it out over the holiday weekend. Now Disk Utility sees the RAID is connected but can’t format it, says
    POSIX REPORTS: THE OPERATION COULDN’T BE COMPLETED. CANNOT ALLOCATE MEMORY.
    No drive icon appears on the desktop either… but disk utility CAN see it there. It just refuses to be partitioned, or set up in any way.
    Tom Matthies replied 13 years ago 4 Members · 12 Replies
  • 12 Replies
  • Rafael Amador
    September 4, 2013 at 2:13 pm
    In DiskUtility, select the volume inside the disk and click the blue link (down in the window) “Mounting Point”.
    rafael
  • Mark Suszko
    September 4, 2013 at 2:30 pm
    “Mount” is grayed out from the top menu.
  • Mark Suszko
    September 4, 2013 at 2:38 pm
    Grabs of what I’m seeing:
  • Mark Suszko
    September 4, 2013 at 2:40 pm
    Any ideas?
  • Rainer Wirth
    September 4, 2013 at 2:43 pm
    What sort of Raid is it? How many harddisks? What controller?
    Why partitioning?
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Mark Suszko
    September 4, 2013 at 2:45 pm
    4-bay, 3 T Promise Raid enclosure. Only one partition.
  • Mark Suszko
    September 4, 2013 at 2:51 pm
    We’re trying something else now: erasing each of the 4, 1-T drives in an external dock, one at a time, D.U. says 6 hours apiece to write zeros across them. Guess I can take a LONG lunch today.
  • Rainer Wirth
    September 4, 2013 at 2:53 pm
    I would swop the drives. Put the drives into other places within the raid. Zero-ing doesn’t help.
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Mark Suszko
    September 4, 2013 at 2:58 pm
    Tried swapping drives around already, no difference.
  • Rainer Wirth
    September 4, 2013 at 3:56 pm
    You can format the drives as single volumes and then put them back into the raid.
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
