Activity › Forums › Apple Final Cut Pro Legacy › raid – stay striped or unstripe?
  • raid – stay striped or unstripe?
    Posted by Mark Slocombe on April 18, 2007 at 9:09 am
    Hi – we have 3x 500gb drives strped Raid 0 in a Macpro for FCP editing, I striped them for speed but having recently lost a LaCie FW drive am getting nervous – I know RAID 0 is fastest, but if you lose one drive, you lose all the media on all the drives… if I copy all the media to a backup drive, I assume I can un-stripe them, ie use them independently – will I see a speed drop in FCP? (It runs fantastically)
    David Bogie replied 19 years, 5 months ago 4 Members · 3 Replies
  • Lee Berger
    April 18, 2007 at 11:27 am
    If you’re editing in DV (25 Megabits/second) then a RAID is not important. Each of those internal SATA drives is plenty fast enough. If you’re planning to edit in higher data rate formats such as 8-bit uncompressed then you’ll need the speed of the RAID. I backup some data from my RAID to inexpensive FireWire drives that I keep powered down after the transfer.
  • Bbalser
    April 18, 2007 at 1:47 pm
    Depends on the codec your using, and if you’re doing multiclip, etc. I use a plain old FW800 500GB LaCie on my QuadCore G5 with DVCPRO-HD 720p24, and I have no problems. If you’re doing HDCAM SR or some other higher end codec, you may have to go with a RAID. There are other forms of RAID that stripe you could use. But it’s for swaping out drives going bad, not a full back-up system.
    If you’re worried about losing data, you should have a dedicated back up system in place. Hard Drive, Tape Drive, DVD, whatever. Dedicated back-ups are NOT replaced by Stripe in a RAID array.
    I’ve seen stripe RAID arrays go bad over the years, with very little recoverable data.
  • David Bogie
    April 19, 2007 at 4:43 pm
    You have not told us why you think you need RAID, which is a misunderstood technology, often upsold to gullible video people.
    see this site for some helpful explanations on the various RAID types.
    https://www.staff.uni-mainz.de/neuffer/scsi/what_is_raid.html
    bogiesan
