Activity › Forums › Apple Final Cut Pro Legacy › raid running very badly in FCP
Posted by Delano Bryant on September 4, 2007 at 1:46 pmSince we upgraded to suite 2. WHen I open a project that was saved on our serial ata raid in FCP. I get the lollipop of death. I don’t get this at all? THe SATA should be lightning fast as before. Obviously there have been some changes to my settings? I’ve deleted my FCP perferences. ANy suggestions?
Is that the color red you want to use?
Delano Bryant replied 19 years, 1 month ago 3 Members · 17 Replies -
Walter Biscardi
September 4, 2007 at 2:01 pmCould be some corruption in the media or something else on the array that FCP is not liking.
Launch the project with the Raid turned off.
Close all the sequences that are open.
Save the Project and Quit FCP.
Turn the Raid on.
Re-Launch FCP and reconnect the media.
If this fails, you have at least one piece of media FCP is not liking.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Delano Bryant
September 4, 2007 at 2:13 pmThanks, I’ll give that a try. Is it safe to run “erase empty areas” out of disk utility. I’ve never heard anyone mention doing this. I thought it might be like running defrag.
Delano Bryant
September 4, 2007 at 2:30 pmWell, I think that scratch disk is still the same as before. It one of the firewire drives.
Delano Bryant
September 4, 2007 at 2:54 pmI thought the scratch disk should be seperate from the drive you edit? Maybe I’ have that wrong.
Peter Wiggins
September 4, 2007 at 2:58 pmThe scratch disk is where you store all your digitised media you edit with.
The boot disk is the drive that your machine will look at first and load the OS from.
Mixing of the two is not recommended.Peter
Walter Biscardi
September 4, 2007 at 3:01 pm[hdfilmmaker] “I thought the scratch disk should be seperate from the drive you edit? Maybe I’ have that wrong.”
You should be using only one Scratch Disk for all of your media. Do not separate your media onto separate drives, this will definitely cause you issues.
Delano Bryant
September 4, 2007 at 3:05 pmOk, I double checked and yes I do use the raid for my scratch. My system has the OS and Apps. When I shut off the Raid and opened up FCP, I could not open the sequences cause they are on the Raid. I turned the Raid on and opened a timeline from a :30sec commercial. It says it will take 5 minutes to render. When its finished I’ll see if it plays without giving me the finger of death(lollipop).
Walter Biscardi
September 4, 2007 at 3:13 pm[hdfilmmaker] “When I shut off the Raid and opened up FCP, I could not open the sequences cause they are on the Raid. I”
What do you mean you can’t open the sequences because they are on the RAID? You should be able to open them up just fine, they will simply have all the media offline. I told you to open the project up this way to ensure that FCP did not try to re-link to a damaged media file or render in a timeline.
[hdfilmmaker] “I turned the Raid on and opened a timeline from a :30sec commercial. It says it will take 5 minutes to render. When its finished I’ll see if it plays without giving me the finger of death(lollipop).”
Is this one from that same project that was not opening before?
