  • Posted by Mo Gardner on July 18, 2005 at 1:56 pm
    This is killing me, my RAID array simply will not mount. A Tech told me that 10.3.9 might have something to do with it, but, could also be something with my card… or SCSI cable…. or…
    Thing is, I’d been running this config for some time before this particular problem started. Got all the latest firmware and everything for my ExpressPCI UL3D. Don’t think the problem lies with any of the drives.
    Anyone have a systematic way to figure things out?
    … ever forward
    Mo Gardner replied 21 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    July 18, 2005 at 2:31 pm
    [Mo]
    Anyone have a systematic way to figure things out?”
    Always best to work with the RAID manufacturer with issues like this. I have used Medea for years and they always work directly with me if I have any SCSI or Fibre Channel issues.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • David Battistella
    July 18, 2005 at 8:23 pm
    Maybe an individual drive in your raid has failed. If it was a raid zero it would not mount. Have you tried to initialize the drive and reformat it. Does it show up in disk utility? Can you mount it from there?
    Simple stuff to torubleshoot.
    David
  • Michael Peele
    July 18, 2005 at 9:55 pm
    Yeah, what type of RAID (brand and type) do you have?
    Is it making any new noises?
    Are the lights flashing differently than usual?
    Have you tried something like techtool pro on it?
    Mike
  • Mo Gardner
    July 18, 2005 at 11:22 pm
    I’m running a Rourke Data setup using Cheetah drives. Just used the ATTO Config Tool and got it to mount… then it went away again. While it was mounted, I ran Disk Warrior on it. Restart gave me the drives back again, then I had to bail for a while. Will check it out this evening.
    What is Tech Tools?
  • Michael Gissing
    July 19, 2005 at 1:12 am
    After upgrading to 10.3.9 my raid went offline as well. I was using an ATTO fibre card. I contacted the ATTO people about this and they sent me a beta software driver that fixed the problem. I suspect the release version of this software has been on their download site for months now.
  • Michael Peele
    July 19, 2005 at 1:17 am
    I am assuming you use software to stripe your disks (most likely ATTO or Apples’ Disk Utility). If you have a hardware RAID’ed array, just erase the array when I say restripe.
    It sounds like you are close – your data is most likely recoverable. If you don’t need your data, just skip the rest of this message and restripe your array.
    TechTool Pro is another disk utility. I tend to have better luck with it finding volumes that don’t mount. If DiskWarrior is able to work on the volume, they are about the same in ability to repair. Nothing beats a variety of utilities when trying to recover a downed volume.
    You may have done this already, but make sure to power down everything, disconnect and reconnect your SCSI cables, power on the drives and then power up the Mac. It’s always good to make sure that your SCSI chain is powered up prior to turning on the Mac. Check that your drives are terminated and that the SCSI ID’s are logically ordered and nothing is set to ID 7.
    If mounting the drive remains an iffy situation, get all the data off that you need while it is mounted. Once you have transfered the data to another drive, restripe your drives (which erases the array).
    If Diskwarrior or TechTool Pro reports lots of errors but manages to recover the volume, you may still want to restripe once you have retrieved your data – just to be safe.
  • Mo Gardner
    July 19, 2005 at 8:18 pm
    Thanks to everyone for your input. Sounds like I’d better restripe before my next big project start.
