Activity › Forums › Apple OS X › RAID not reading drive
  • RAID not reading drive
    Posted by Naveen Mallikarjuna on May 19, 2010 at 6:19 pm
    So, I thought I had a hardware failure in my array. I have a Mac Pro with 3 1TB Seagate drives in bays 2,3, and 4. My array disappeared from my OS. Open up the box, and the drive in bay 3 is kaput.
    Or was it?
    I hooked it up to an external dock and it fired up. So I swapped another drive into that bay and it seemed not to work.
    At least, it doesn’t show up in Disk Utility. DU seems to recognize a drive in bay 2 and 4, but not 3.
    Is this a hardware problem (which is what I’m assuming)? And if so, is this the forum for this issue? And if the answer to that is yes, then any suggestions on what I should do?
    Thanks in advance.
    Rainer Wirth replied 16 years, 4 months ago 3 Members · 2 Replies
  • Zane Barker
    May 20, 2010 at 5:46 am
    Sounds like the connections in the 3rd drive slot are bad which probably means you need a new logic board.
    Make an appointment at your local apple store.
    Hindsight is always 1080p
  • Rainer Wirth
    May 21, 2010 at 9:52 pm
    internal raids are not very reliable. They get too hot. Did you do a raid 5 raid or raid0. If you did A RAID 0 the data is gone. There is a software called techtool pro. It can localize your issue.
    I hope this helps.
    Rainer
    I think Zane could be right
