Activity Forums Blackmagic Design Raid help – onboard controller or Raid card. . .
  • Raid help – onboard controller or Raid card. . .
    Posted by Vince909 on May 9, 2006 at 7:09 am
    Im getting around 100Mbs right now from my onboard XP raid controller (Asus A8n-SLI Premium) and my 4 drive stripped RAID (4 WD 250gig SATA II drives); should I upgrad to a Sonnet E4P tempo PCIe card (or similar). Will it make that much difference in a increase in speed ? or save the money on the card. . .THanks
    Alan Hunter replied 20 years, 4 months ago 5 Members · 9 Replies
  • 9 Replies
  • Bob Zelin
    May 9, 2006 at 10:19 pm
    2 Hitachi or Seagate SATA drives with an E4P will give you about 128mb/sec.
    So 4 drives (put them in a nice external enclosure, like a Firmtek 4 bay, or Sonnet Fusion 500) will dramatically increase that performance.
    Bob Zelin
  • Phil Harbath
    May 10, 2006 at 6:58 am
    maybe try the nvidia raid, if you haven’t already. i switched to it and got much better results.
    phil
  • Bob Zelin
    May 10, 2006 at 10:23 pm
    Maybe I have been asleep, but NVidia makes graphics cards, not RAID controllers. What model NVidia raid controller do you have ?
    Bob Zelin
  • Phil Harbath
    May 10, 2006 at 10:35 pm
    the motherboard for that model is a nivida nforce4 motherboard chipset. the newest drivers for the raid are
    on the nividia website.
  • Gary Taylor
    May 12, 2006 at 1:37 am
    Hi Jamination,
    I am also looking at that motherboard for a system. Do you mind sharing what drives you are using and what kind of performance are you getting with NVIDIA RAID O?
    Gary
  • Phil Harbath
    May 12, 2006 at 2:06 am
    i have 3 wd320 drives connected with a read/write speed of 163.
    we have been using it for about 2 months with no problems. when i had
    them connected to the other controller i had speeds less than 80.
    phil harbath
  • Gary Taylor
    May 12, 2006 at 11:22 am
    Thanks Phil,
    Those are some pretty amazing numbers or onboard RAID. Did you ever try it with all four SATA channels?
    Thanks again,
    Gary
  • Phil Harbath
    May 12, 2006 at 4:50 pm
    no i hadn’t tried yet. some time in the next couple months i will add a drive. i have another decklink computer with 4 and an adaptec card that gets
    around a speed of 200, i am hoping i get something around there.
  • Alan Hunter
    May 15, 2006 at 12:43 pm
    Vince,
    I’ve been using a Silcon Image 3124-2 Multiport host board with two outboard boxes (inside a Silcon Image 3726 chip) with 4 WD SATA II 250G in each, read speeds are about 214-220 with write speeds averaging about the same. This is a fairly inexpensive way of moving to an outboard raid system without having to drop some big bucks.
    Alan
