Activity Forums Storage & Archiving RAID drives
  • RAID drives
    Posted by Alex Johnson on April 26, 2012 at 5:52 am
    So I’m thinking of building a data kit – if I have a raid unit like the Lacie Thunderbolt 2big and I tell it to use mirroring, then can I then pull the drives and use them independently? Will they mount if I put the drives in a drive toaster? Or would they just insist on rebuilding the array?
    Evan Crush replied 14 years, 3 months ago 3 Members · 2 Replies
  • Jon Schilling
    May 1, 2012 at 4:31 pm
    Alex,
    I was waiting to see if anyone else would respond & since they didn’t…
    Bottom line: You aren’t going to be able to “split up” the RAID set & then use each drive as it’s own.
    Generally with any RAID, once it’s RAID’ed, that’s it. 2 drives in JBOD is 2 volumes, no problem doing what you want to do. 2 drives in RAID 0 always will be in RAID 0. 2 drive mirrored (RAID 1) will always want to be mirrored.
    Jonathan Schilling
    Vertical Sales Manager
    Proavio
    12221 Florence Ave.
    Santa Fe Springs, CA 90670
    Dir: 562-777-3498
    Main: 562-777-3488 X106
    Fax: 562-777-3499
    Email: jon@proavio.com
  • Evan Crush
    June 4, 2012 at 3:55 pm
    euh… since the RAID used is the Mac OS one I would think that when a drive is read independantly, the drive would appear as a member of a failed RAID 1 array but your data should still be readable.
    Now what happens when you put booth drive back together in a RAID 1…??? one would need to do the test…
