Activity Forums Storage & Archiving RAID Drive Continuously Develops Bad Blocks
  • RAID Drive Continuously Develops Bad Blocks
    Posted by Wes Browning on May 2, 2012 at 2:50 pm
    I have a RAID drive that keeps developing bad blocks, and even after switching out drives, I continue to get errors. The message I receive from Drive Genius is: “OWC Mercury Pro RAID Media (“media” is the volume’s name) contains to bad blocks. The drive should be backed up and erased as soon as possible.”
    Here’s my current configuration:
    OWC Mercury Pro RAID drive (eSata/FW800/USB connections) – Configured as RAID 0
    Two Hitachi DeskStar 7K3000 2TB drives.
    Sonnet Echo ExpressCard/34 Thunderbolt adapter with Sonnet Tempo SATA ExpressCard/34 Controller Card (using eSata from drive to convert to Thunderbolt connection)
    iMac mid-2011 machine with Thunderbolt ports, running most Adobe Premiere and After Effects
    I originally had Seagate drives in it back in January, but then put new Hitachi drives in it last month. Its still developing bad blocks though.
    Jon Schilling replied 14 years, 4 months ago 2 Members · 1 Reply
  • Jon Schilling
    May 2, 2012 at 4:19 pm
    Wes.
    Have you tried contacting OWC directly on your issue? I’d do that as a 1st step. Make sure the drives you’re using are compatible with their enclosure.
    Jonathan Schilling
    Vertical Sales Manager
    Proavio
    12221 Florence Ave.
    Santa Fe Springs, CA 90670
    Dir: 562-777-3498
    Main: 562-777-3488 X106
    Fax: 562-777-3499
    Email: jon@proavio.com
    See our forum: https://forums.creativecow.net/proavio
