Activity Forums Storage & Archiving RAID configuration gone!
  • RAID configuration gone!
    Posted by Craig Rogers on July 19, 2013 at 3:52 am
    I moved my workstation to a new facility and upon bootup, I was greeted with a warning that multiple ECC errors had been detected on my RAID controler DIMM. It suggested the DIMM be replaced less I risk likely corrupt data.
    So, I ordered a new DIMM. Installed the DIMM, boot up gave me the same exact error message. Whaa??
    Borrowed another controller card (Dell perc H800, same as my bad one) and everything booted up a-ok, but it no longer sees my RAID configuration at all.
    Any ideas how I can get my data back?
    PS – this is even weirder…the RAID control management software seems to be gone as well. Anyone have a link to where I can re-download it? I believe it was LSI megaRAID software?
    Ericbowen replied 13 years, 1 month ago 4 Members · 4 Replies
  • Craig Rogers
    July 19, 2013 at 5:29 pm
    workstation specs…
    Win7 Ultimate 64-bit – os
    ASUS Z9PE-D8 WS – motherboard
    Intel E5-2650 (x2) – cpus
    32GB Kingston KVR16R11D4K4/32 – system memory
    ASUS GTX 690 4GD5 – graphics card
    Dell Perc H800 RAID controller
    Seagate 3TB (x8) drives in Sans Digital TR8X+BP enclosure
  • Rainer Wirth
    July 22, 2013 at 12:52 pm
    Don’t touch the raid! Rebuildt your system, get the raid software and run hardware checks including cable.
    Then try and switch on the raid.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Paul King
    July 22, 2013 at 3:25 pm
    I take it the replacement controller was a newer model?
    Contact LSI support. My experience is mostly with Adaptec and Areca, both of which can recover lost RAID setups.
    There will be a way in the megaraid software to do this, and it may involve re-establishing the RAID WITHOUT building (skip initialise).
    If it works, Windows will see it’s NTFS partition again, although you may need to import the RAID in disk administrator.
    Again, email LSI and check with them for the correct procedure.
  • Ericbowen
    July 31, 2013 at 3:37 pm
    If that is an LSI raid controller then you can get their standardized Web management here:
    https://www.lsi.com/downloads/Public/MegaRAID%20Common%20Files/13.04.03.01_Windows_MSM.zip
    Go under the controller options once you have the raid management installed and look for scan for foreign configuration. Follow the wizard prompts to get the raid volume back online.
    Eric-ADK
    Tech Manager
