Activity › Forums › Apple Final Cut Pro Legacy › RAID Block Size?
RAID Block Size?
Posted by Dan Brockett on March 24, 2009 at 6:27 pmHi all:
I am walking a friend through setting up their RAID on their new Mac Pro to edit with FCP. They are setting up two of their internal SATA drives as a RAID 0. When you go into disk utility and configure in the RAID tab, under options, you have the ability to chose RAID block size. The options range from 16K all of the way up to 256K. The default is 32K. Do we want to leave it at the default 32K or change it? We have two 1 TB internal SATAs and she will be using this to edit video using AVC Intra, AVCHD, DVC Pro HD and DV.
I know nothing about RAID block sizes. What does this control do? Any advice?
Dan
Kimberly Nicole replied 17 years, 2 months ago 4 Members · 7 Replies -
David Roth weiss
March 24, 2009 at 6:48 pmSmaller block sizes are the way to go if your RAID will be primarily devoted to reading and writing small files such as text and database files. If you deal with larger chunks of data—beefy video and audio files, for example—choosing a block size of 256K will move your data more efficiently.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Dan Brockett
March 24, 2009 at 9:08 pmThanks for that David, I didn’t have a clue about it.
Dan
Providing value added material to all of your favorite DVDs
Walter Biscardi
March 24, 2009 at 11:04 pm[Dan Brockett] “I know nothing about RAID block sizes. What does this control do? Any advice? “
I would call the RAID manufacturer and ask them. Based on what you’re doing they will instruct you to set up a particular block size.
For instance we run ATTO R-380 cards on our local storage and based on the fact that we primarily run in compressed HD, they had us set up the block size one way. If we were working primarily in uncompressed HD, we would have gone a different size.
Same with our new SAN array. It’s been optimized for ProRes with a particular block size.
One size does not fit all and there is no way to properly answer your question on a forum like this. You should contact the controller or drive manufacturer for advice.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Dan Brockett
March 24, 2009 at 11:54 pmHi Walter:
I appreciate the advice, but not sure if you read the details in my inquiry? This is for a friend who is setting up the smallest, lowest budget RAID possible, an internal SATA RAID on a new Mac Pro. No controller, no cards, no hardware other than the drives, just a couple of SATA drives and the drive utility, there is no hardware manufacturer to ask unless you think I should call Hitachi?
Dan
Walter Biscardi
March 25, 2009 at 10:32 amHi Dan,
For that very simple setup you’re probably good to go with pretty much anything really. When you get into the larger RAIDs, you really want to contact the manufacturer of the controller as the Block Size really does affect performance depending on the resolutions you’re running.
I never realized that until two years ago when we were dropping frame for no reason running DVCPro HD and the folks at ATTO explained how the block size helps to “tune” the performance of the RAID. Really cool stuff, but if it’s set up wrong, it can cause a lot of frustration. I’ve learned more than I ever wanted to know about block size recently with our SAN installation.
Have fun!
Dan Brockett
March 25, 2009 at 3:05 pmHi Walter:
Thanks for your input, I appreciate it. I thought the same thing and I know when setting up a real hardware-based RAID that I would contact the manufacturers.
Dan
Kimberly Nicole
June 19, 2009 at 6:49 pmIs there an advantage to using a block size larger than 256K? I am editing XDCam EX footage, which, in .mp4 format, is 16G for 57 minutes or 287MB per minute, 4.8MB per second, and 204K per frame at 24fps native.
