Activity › Forums › Compression Techniques › raid advice
  • Posted by George Sloan on February 6, 2011 at 4:51 pm
    Please advise as to best way to speed up compression with present drives and perhaps a modest investment.
    George
    George Sloan Productions
    Hayesville, NC https://www.sloanmotion.com
    MacPro Intell 2,66mhz>FCP7>Prores>compressor>Toast> 30 minute broadcast “MUsic mountain” delivered on DVD downconverted to SD
    6gb ram, Drives:Internal 4x250GB..External 1 500GB(Western Digital) and 1TB G Raid2.
    Do not have apple raid card.
    http://www.sloanmotion.com
    “Music Mountain” Channel 4 Windstream Cable TV
    Cannon Xh A1 1080i>FCP7>ProRes>SD DVD>Delivery on DVD to Broadcast and DVD distribution
    Craig Seeman replied 15 years, 7 months ago 3 Members · 5 Replies
  • Craig Seeman
    February 6, 2011 at 5:08 pm
    RAID isn’t going to get you much as hard drive speed is not the bottleneck.
    Create a QMaster cluster. It can range from multiple cores to multiple computers.
    Also consider file based FTP delivery and skip the heavily compressed and burned DVD.
    Compare the speed of third party encoders to Compressor, such as Telestream Episode or Squeeze for example.
    BTW the subject might not attract the best attention because I don’t think you need raid advice at all. It’s best not to make assumption and just ask the question, “how to speed encoding and delivery”
  • Jeff Greenberg
    A raid really won’t make a significant difference; the bottleneck is the MPEG2 compression;
    I’m not sure that Toast is using all the processors. You should check by running toast and also running Activity Monitor (which has a gauge to show off processor performance.) You may find that using Compressor, using multiple cores provides a faster encode than Toast does. I don’t know if Toast will know to not reconvert valid MPEG-2 files when making a DVD
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • George Sloan
    February 6, 2011 at 8:35 pm
    Thanks Craig,
    I am currently using a qmaster cluster with good results over 4 cores. JUst wondering what would be a significant step up from here. Currently using a firewire800 connection woud a sata card help much
    or perhaps a bigger raid?
    george
  • George Sloan
    February 6, 2011 at 8:39 pm
    Thanks Jeff,
    I’ll run a ck on toast as you said. As for reencode. Toast has a “never” setting.That I am using.
    George
  • Craig Seeman
    February 6, 2011 at 8:42 pm
    I don’t think going from firewire800 to sata would help all though much. Hard drive throughput is not the bottleneck. The best bet would be to expand the cluster to other computers IMHO. Alternately a hardware accelerator. For H.264 I’d recommend Matrox CompressHD or MXO2 with MAX but it seems you’re trying to speed up MPEG2 encoding.
