Activity › Forums › Apple Final Cut Pro Legacy › RAID 5? Any takers. Advice appreciated!
Posted by Jeff Scott on January 13, 2006 at 1:09 amI’m looking to upgrade my Final Cut bay with the AJA KONA LH card and am planning
on building an external SATA RAID. I really like the security of a RAID 5 set-up.
Most of my work will be in the SD space, capturing and outputing BETA-SP.What are your thoughts of RAID 5? Speed? Reliablity? What’s the best host card?
Jeff
Current System: Dual 2Ghz G5, 2G RAM
Torrey Loomis replied 20 years, 8 months ago 5 Members · 5 Replies -
Jerry Alto
January 13, 2006 at 2:16 amJeff- Why cut your storage in half by using Raid 5? What’s the downside to raid 0? So you have to redig… no big deal. If you’re doing 8-bit uncompressed you need the speed of raid 0.
We’ve done three systems now with external SATA and love it. Seri-tek (Firmtek) cards have worked very well for us. Go with the one with 4 external connectors. SATA II is close (if its not already here) so you may want to see if its available or worth waiting for. FWIW.
JerryG5 Dual 3GB Ram
FCP5 Studio
External 1 TB SATA Raid 0
Kona LH, Second system w AJA ioLA
Sony Z-1 -
Tim Vaughan
January 13, 2006 at 1:19 pmWe have the Apple Raid (RAID 5 setup) with a QLogic Fibre Sanbox and XSan, and I haven’t had any trouble working with Beta SP in SD and mini-DV projects. We absolutely MUST have my projects backed up, and the overall performance has been very good. We are not editing to HD yet, and when we reach that point, we’ll most likely get another unit and dedicate that to speed, and keeping the 1st to redundancy. But the most important thing to us is backup. (I am currently rebuilding a project that was stored on an external drive, and that drive failed. While the FCP files where backed up locally, all After FX projects are having to be rebuilt watching the copy. A real pain in the ….)
But that is just my 2 cents…..Tim
Tim
Jerry Alto
January 13, 2006 at 5:31 pmTim- We understand that backup is super important but we feel backing up on our media drives is NOT the way to go. In our case we save all the graphics and project files on an external firewire drive that is not part of the everyday system. We also output an 8-bit uncompressed quicktime movie of our 30 min. show (about 32 gigs). If there is a simple fix later on we transfer the file to the media drives, drop the file into FCP and make the fix and we’re on our way.
We have even taken it a step further. Our dub house has FCP5 and we deliver him the quicktime movie and he goes out to vhs for closed captioning then to Digibeta for our dub master.
We feel that you are asking for trouble when you mix backup files with active media files. We also understand that different workflows demand different strategies. Just sharing a workflow that has worked for us.
FCP5 Studio
Sony Z-1 -
Torrey Loomis
January 14, 2006 at 3:54 amJeff,
Some folks simply cannot be down for any length of time – hence the security of RAID 5 makes sense for them even if they sacrifice drive space.
For others, RAID 0 is fine because they have the time to go back to their original media.
You need to decide which side you fall on before you jump into the equipment pool.
Give me a call – I can help you on this.
Torrey Loomis
President – Silverado Systems
Apple Pro Video VAR
