Activity › Forums › Apple Final Cut Pro › RAID 5 formatting for PROMISE Pegasus2 R6 12TB (6 x 2TB) Thunderbolt 2 RAID System for FCPX 10.1?
  • RAID 5 formatting for PROMISE Pegasus2 R6 12TB (6 x 2TB) Thunderbolt 2 RAID System for FCPX 10.1?
    Posted by Peter Dunphy on March 14, 2014 at 2:18 pm
    Hi Guys
    We have installers coming to set up a PROMISE Pegasus2 R6 12TB (6 x 2TB) Thunderbolt 2 RAID System on Tuesday.
    Would you suggest the system is formatted to RAID 5 For FCPX 10.1 editing?
    Tim Jones replied 12 years, 6 months ago 8 Members · 21 Replies
  • 21 Replies
  • Tim Jones
    March 14, 2014 at 3:29 pm
    While it would be great if there could be a cut and dried answer, there are a few questions here that you should consider –
    • Are you using Enterprise-grade disks or consumer-grade disks?
    • Are you going to use the array for long term storage, or just day to day editing operations?
    • Are you backing the content up to an alternate device (disk, tape, cloud)?
    • Do you need the full 12TB, or is 10TB enough (the difference between RAID 0 and RAID 5 formatting)?
    • If you are using Enterprise-grade disks, the disks have a much longer MTBF, so RAID 5 over RAID 0 (striping) is less of a requirement.
      If you are using the array for long term media storage, RAID 5 gets a nod.
      If you are backing up the content regularly, RAID 0 gets a nod if you’re backing up.
      If that extra 2TB makes a difference, then RAID-0 wins.
      Tim
      Tim Jones
      CTO – TOLIS Group, Inc.
      https://www.productionbackup.com
      BRU … because it’s the RESTORE that matters!
  • Gary Adcock
    March 14, 2014 at 4:03 pm
    [Peter Dunphy] “We have installers coming to set up a PROMISE Pegasus2 R6 12TB (6 x 2TB) Thunderbolt 2 RAID System on Tuesday. “
    Why? it is a plug and play system, the config utility is simple and easy to understand.
    I always recommend using Raid 5 at minimum, if you need that extra 2TB for something you should have bought a bigger array, NOTHING in post is more painful than loosing data to dead drives, at least with riad 5 redundancy you have some safety net on your projects.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    Follow my blog at https://www.garyadcock.com
    Or follow me on Twitter
    @garyadcock
  • John Davidson
    March 14, 2014 at 5:08 pm
    Exactly right Gary. Plug it in and leave it alone. It’s preformatted as RAID5 and that’s exactly what you want.
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Bret Williams
    March 14, 2014 at 8:22 pm
    Mine did have to go through some routine that took all night though.
  • Gary Adcock
    March 14, 2014 at 9:52 pm
    [Bret Williams] “Mine did have to go through some routine that took all night though.”
    I have most of the monitoring tools set to run in the background, and I NEVER have any external drive set for journalling.
    They come formatted out the of the box, but overnight for 12+ TB is pretty good, it would take the early Xraids what seemed like forever to format 4 or 6 TB of space.
    gary adcock
    Studio37
    Chicago, IL
    @garyadcock
  • Jason Jenkins
    March 14, 2014 at 9:56 pm
    My Pegasus R6 (6TB) took around 24 hours to get through the setup, which was waaaay longer than the instructions indicated. No problem, just unexpected and disconcerting.
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
    Check out my Mormon.org profile.
  • Bret Williams
    March 14, 2014 at 9:58 pm
    I forget what it’s called, but yes it was already formatted for raid 5. It just had to do some process that took many hours or overnight until it had full speed. I just have the r4 8tb, so I take a 25% space hit. But mine is my current projects drive. When projects are done I consolidate them to a mirrored raid. A guardian Maximus from newer tech.
  • Peter Dunphy
    March 15, 2014 at 12:16 pm
    **Are you using Enterprise-grade disks or consumer-grade disks?
    Here’s the info I got about the type of disks in the Pegasus2 we’ll be receiving:
    “I’ve done a little bit of research and I can confirm that the Promise Pegasus R6 Drives are enterprise grade hard drives. They are 7200 rpm SATA drives that are made by Promise.”
    **Are you going to use the array for long term storage, or just day to day editing operations?
    **Are you backing the content up to an alternate device (disk, tape, cloud)?
    nope
    **Do you need the full 12TB, or is 10TB enough (the difference between RAID 0 and RAID 5 formatting)?
    10TB is fine
  • Gary Adcock
    March 15, 2014 at 3:33 pm
    [Peter Dunphy] “”I’ve done a little bit of research and I can confirm that the Promise Pegasus R6 Drives are enterprise grade hard drives. They are 7200 rpm SATA drives that are made by Promise.””
    I do not know where you got that info but it is incorrect- Promise does not make any hard drives,
    Drives listed in my units (I have 5 units) are all from Hitachi and can be checked via the serial numbers and model used in the Promise Raid Utility App.
    gary adcock
    Studio37
    Chicago, IL
    @garyadcock
  • Peter Dunphy
    March 15, 2014 at 5:00 pm
    Interesting Gary, thanks for the info, will check it out.
  • Page 1 of 3
