Activity › Forums › Storage & Archiving › Raid 1 Mounted as 2 Hard Drives
  • Raid 1 Mounted as 2 Hard Drives
    Posted by Matt Dunne on December 8, 2014 at 12:54 pm
    Hi everyone, I”m hoping you can help me. I have a Lacie 2 Big Thunderbolt Raid that I use for a backup. I removed the disks and put new ones into the enclosure. I have an external dual drive enclosure that I can use for accessing the other drives from the previous raid. It has been working and today when I plugged the drives of the old raid into the enclosure it mounted as 2 separate drives but with the exact same name and same files instead of a raid. I’m on a Mac and checked disk utility and sure enough they weren’t Raid slices but separate drives. Has this happened to anyone before and is there a reason it would do this all of a sudden?
    I’m also wondering if it’s the enclosure I’m using to access the drives. It doesn’t say anything directly about supporting raid 1 so I’m wondering if a different dock is recommended? I’m using these for access to archive files and to periodically plug is so they can be synced with Back Blaze.
    Thanks in advance.
    Matt Dunne replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
