Activity Forums Apple OS X RAID 0 interesting problem, DW sees it, Disk Utility doesn’t in app, but does in Terminal
  • RAID 0 interesting problem, DW sees it, Disk Utility doesn’t in app, but does in Terminal
    Posted by David Schneider on March 15, 2011 at 5:59 pm
    So I have a 3 drive (3x500gb) Internal RAID0 set up for speed. It is also backed up in another place.
    I have encountered an odd situation. I used diskwarrior 4.1.1 and ran it on the RAID. After running it, I was asked if i wanted to replace the current structure with the new structure. I said yes, as I was able to preview it and it looked fine.
    Now… restart… and RAID doesn’t show up on the desktop. Check Disk Utility and it is there but not as a RAID, but rather as 3 RAID slices.
    go to the command prompt and type in checkraid
    and it sees all 3 drives, tells me they are online.
    so I go back into DW and run the rebuild again. This time I only can bring up the RAID as the Preview. but when I tell it to replace… nothing appears on the desktop.
    I am afraid the 1st DW run may have caused some problems with the partition table?
    This was the 1st time I had run DW on this Striped set.
    Now I am just curious how (can I?) to get it back.
    I have heard about copying partition tables, re-initializing with the same parameters etc…
    but does anyone have any thoughts about it? since it is all backed up, I am willing to take a chance… but also quite interested in figuring this out just for my knowledge.
    THanks for any thoughts you all might have.
    I have searched for similar situations, but I usually come across a RAID0 drive failing… which is not the case for me. they are all there… i just can’t get them to come up as one drive…
    David
    David Schneider replied 15 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
