Activity › Forums › Apple Final Cut Pro Legacy › RAID-0 for boot drive?
  • RAID-0 for boot drive?
    Posted by Brad Bussé on September 16, 2009 at 9:13 pm
    How many use a RAID-0 for their boot drive? My media is on my X-RAID, my Boot Camp Windows install is on another drive, and I backup my system drive to an external with Carbon Copy Cloner. Is there a reason not to do this, e.g. – does software raid for a system drive create issues?
    Sean Oneil replied 17 years ago 5 Members · 5 Replies
  • Shane Ross
    September 16, 2009 at 9:34 pm
    There is no reason TO do this. It won’t speed up your OS significantly. All you will end up doing is raising the risk of losing your OS drive. Because if one of those two or more drives fail, then you lose the whole kit and kabootle. Gone. Just use a single drive for your OS.
    Shane
  • Devin Crane
    September 16, 2009 at 9:44 pm
    You might consider the opposite and go RAID-1 in to protect yourself from a drive failure.
  • Brad Bussé
    September 16, 2009 at 10:31 pm
    Well, I was thinking it would speed up startups and app loading times. Also, wouldn’t it help the OS to run faster with caching? Like when I look in the Activity Monitor it says that my VM is 100 GB in size. I have 16 GB of RAM so I’m not paging out often, but I still wonder how much it could help with the VM caching.
  • Chris Tompkins
    September 16, 2009 at 10:49 pm
    Ya, that’s a bit nuts. Go with 1 drive as a boot-up drive. Preferably an internal.
    Chris Tompkins
    Video Atlanta
  • Sean Oneil
    September 17, 2009 at 4:56 am
    Get a solid state drive if you really want to increase speed. Use time machine or something similar for backups. RAID should never be used for the startup disk.
    Sean
