Activity › Forums › Adobe After Effects › Radio Waves Nube Question
  • Radio Waves Nube Question
    Posted by Norman Greenwood on March 3, 2009 at 6:19 pm
    I am finally getting into AE and already have many ideas on how I would like to use it.
    One such idea involves the Radio Waves effect, but I have a problem:
    How do I get the effect to show over an image or video?
    I apply the effect to the image I want, but the image disappears and leaves only the radio waves.
    Thanks for the help.
    Norman Greenwood replied 17 years, 7 months ago 3 Members · 3 Replies
  • Kevin Camp
    March 3, 2009 at 6:43 pm
    2 ways i can think of…
    the most common way is to work with the effect on a separate layer… choose layer>new>solid, make it comp sized, then add the radio waves effect to the solid. if the solid is over the video layer, then you’ll have what you are after. you can also place other layers in between and the radio waves effect will show over the top of those too.
    if you want to leave it on the footage layer, you’ll need to add one more effect to re-composite the layer under the radio waves effect. add the effect ‘cc composite’ (effects>channel>cc composite). set the ‘composite original’ dropdown to ‘behind’ and uncheck the rgb only option.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Paul Conigliaro
    Create a solid in the comp and apply the radio waves effect to that, then you can play with the various transparency modes & opacity to reveal the clips underneath.
    CS3, FCS2
    [Note: Using Particular, 3-D Stroke, and now Form do not instantly make your designs “teh awesome.”]
  • Norman Greenwood
    March 4, 2009 at 8:39 am
    Thanks guys, I really appreciate it. I thought it would be something like that, but my mind was fried by that point.
