  • Posted by Adam Goddard on July 17, 2017 at 2:18 am
    Hi
    I am hoping there is an expression that ramps the expansion setting of Radio Waves plugin; what I would like to happen is have the gaps between the lines of the circles closer together at birth then as they animate outward the gaps are larger between the lines.
    Like this logo artwork, I have in Illustrator
    Changing the expansion amount creates equal gaps from birth to death. Does anyone have any idea on how this might be solved? Thank you.
    Adam Goddard replied 9 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
