Activity Forums Apple Final Cut Pro Legacy Radio Squelch Audio Transition Technique
  • Radio Squelch Audio Transition Technique
    Posted by Tony Young on October 6, 2008 at 12:35 am
    Hey there, a technique question, rather than a technical one:
    I’m working on a short ‘In Memoriam’ piece for a former radio jock. A number of his audio tracks have a distinctive sounding transition between them that you’ve probably heard on radio before. The music is playing along, and the transition sounds like the track is slowed down suddenly and then sped up before ending in a high pitch ‘squelch’. It’s reminiscent of the moment you start shuttling forward on a deck. In total, it might last one second, but it’s quite effective for changing from one music clip to the next.
    At first, I thought it was just a stock sound, but each transition is slightly different, coming straight out of the last note of the music. I thought that maybe I’d be able to emulate it by speeding up the audio, but increasing the speed sounds–well, just like sped up audio.
    I tried working with the variable speed option, but this doesn’t seem to be affecting the audio–just the visuals.
    Any thoughts on how they might have done this, how I might emulate it? Thanks for any ideas in advance.
    Tony Young replied 17 years, 10 months ago 1 Member · 1 Reply
  • Tony Young
    October 7, 2008 at 10:49 pm
    Thanks, Dave. The After Effects idea is a good one, and the HAL effect is the kind of thing I’m looking for. Sounds tricky, but I bet that’s about the only way to make it happen. I’m not terrific in After Effects–I wonder if there’s anything in SoundTrack that would work.
    It’s odd that the variable speed option in FCP doesn’t effect audio, as far as I can tell. I’m still on 5.1, so maybe it’s been changed.
    Anyhow, thanks for the idea!
