Activity Forums Adobe After Effects Radial Lines
  • Ridley Walker
    February 12, 2013 at 8:58 pm
    This should be fairly easy to do using shape layers and repeaters.
    Make a rectangle shape adjust the width and height then add a repeater.
    Set the repeater transform position to 0 in the x any y. Set the number of copies to your desired number. Set the rotation to the number of 360/ the number of copies.
    Animate size and position for the rectangle path.
    See: 5439_shapeanim.aep.zip
  • Todd Kopriva
    February 12, 2013 at 9:01 pm
    Here’s one way, with a shape layer with a circular path, a dashed stroke, and a Repeater:
    After Effects team blog
  • Todd Kopriva
    February 12, 2013 at 9:02 pm
    Looks like Ridley beat me to it. Good to get confirmation, though.
  • Rob Rosko
    February 12, 2013 at 9:44 pm
    Thanks a lot guys. Exactly what I needed.
  • Ridley Walker
    February 12, 2013 at 9:49 pm
    And Todd confirms there is an alternate method!
