Activity Forums Adobe After Effects radial gradient
  • radial gradient
    Posted by Chris Burns on March 17, 2010 at 1:40 pm
    I’m having problems with color banding when using radial gradients. I know I’ve seen it somewhere in a tutorial, but does anyone know how to get rid of this?
    Thanks, Chris- Mn
    Todd Kopriva replied 16 years, 6 months ago 3 Members · 2 Replies
  • Eddie Yepez
    March 17, 2010 at 2:11 pm
    Hi,Change the proyect to 16 or 32 bits.
  • Todd Kopriva
    March 17, 2010 at 3:08 pm
    Also, check to see whether the banding persists in your output files. In most cases, the banding that you see in previews goes away in the output. The reason is that After Effects introduces dithering when generating gradients in 8bpc output, but that dithering isn’t done for the preview in the Composition panel. Also, note that banding that you see on a common LCD monitor is often a result of the quantization done by the monitor itself.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
