Activity Forums DaVinci Resolve R9b2 messes up colors when rendering R3D
  • R9b2 messes up colors when rendering R3D
    Posted by Gino Amadori on August 15, 2012 at 4:24 am
    Hi there I was wondering if anyone else has been Gavin this issue:
    When I render some R3D files I get some high and low luminance areas of my image turn either yellow or blue. I am using my MacBook pro 17′ SSD 512 8Gb Ram.
    I was also wondering if there was a way to take the R9r2 project back to resolve 8.2.2.
    Thanks guys. I really appreciate any help
    Anmol Mishra replied 14 years ago 6 Members · 9 Replies
  • 9 Replies
  • Rohit Gupta
    August 15, 2012 at 5:01 am
    What format are you rendering to, and what’s your Mac OS version?
  • Sascha Haber
    August 15, 2012 at 7:43 am
    Probably your display was clipping to white before..
    Try lowering your light level, does the same happen ?
    If so, make sure your highlights outside the visible range are still neutral with a highlight dasaturation node.
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
  • Gino Amadori
    August 15, 2012 at 11:53 am
    I’m rendering to ProRes 4444 and am using the latest version of snow leopard. I’m using R3D from an Epic. I’m using an external FireWire 800 drive to pull the images from there.
  • Gino Amadori
    August 15, 2012 at 11:58 am
    I thought this might be the case too, clipping. But its strange because it happens on both shadows and highlights. I will soften the highlight clipping and the lows too and see if it works. Thanks for the advise an I will let you know how it went.
    Thanks again
    Any idea on getting my project back to 8.2.2?
  • Matthew Riggieri
    August 16, 2012 at 6:15 pm
    Gino
    Is that the 2011 Macbook Pro17″ with an ATI card?
    Blackmagic has acknowledged there is a issue with OpenCL rendering in R9 on Lion 10.7.4. I see the same issue. the only fix right now is to set your render speed to 1%.
    Hopefully they will fix this soon, as it ruins my on set Dailies workflow.
    Matt
  • Dwaine Maggart
    August 16, 2012 at 7:35 pm
    Updating to Mountain Lion is the currently preferred OpenCL fix.
    Although I just read that there is apparently a Lion 10.7.5 release that will happen, and maybe the OpenCL issue will be fixed in that?
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Gino Amadori
    August 17, 2012 at 4:45 am
    Ahh that’s it then. I was really frustrated rendering clips. Thanks for letting me know Matt. Hope this gets solved soon because I was starting to like version 9 and now i had to go back to 8.2.2.
    Gino
  • Gino Amadori
    August 17, 2012 at 4:50 am
    Hi Dwaine, thanks for the info, is this issue fixed with release of Beta 3?
    Thanks again
    Gino
  • Anmol Mishra
    September 5, 2012 at 8:41 am
    Hi Dwaine.
    Does the 10.7.5 beta release fix the issue ?
