Activity Forums Adobe After Effects R3d workflow with output to resolve maintaining lattitude
  • R3d workflow with output to resolve maintaining lattitude
    Posted by Jeremy Webb on June 9, 2015 at 4:17 pm
    I have some shots that need to have some screen replacements done and then sent off to color correct. The shots are supplied as r3d (although I could potentially get them in a different format if it would be easier). I am concerned about making sure I am passing on all of the raw file information to color correct. I’ve tried to find a tutorial for this workflow but there doesn’t seem to be much out there. What is the easiest way to do this in AE?
    Walter Soyka replied 11 years, 2 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    June 9, 2015 at 5:23 pm
    You can’t pass through the RAW file information because you can’t render out a RAW file because the data it has is created in camera. You could probably use an EXR sequence.
  • Jeremy Webb
    June 9, 2015 at 5:31 pm
    I realize I won’t be able to render out an r3d file, but I’m looking for best practices in setting up a workflow and rendering out to dpx/exr/cinemadng
  • Walter Soyka
    June 9, 2015 at 6:48 pm
    [jeremy webb] “I realize I won’t be able to render out an r3d file, but I’m looking for best practices in setting up a workflow and rendering out to dpx/exr/cinemadng”
    There is no one right way to do this. Talk to your colorist about how they’d like to work.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
