Activity › Forums › DaVinci Resolve › R3D -> Premiere Pro -> Resolve: LUT should I do?
  • R3D -> Premiere Pro -> Resolve: LUT should I do?
    Posted by Michael Morgenstern on February 24, 2014 at 6:40 am
    Hi all,
    I shot a project on the RED Scarlet and did a lot of tweaking to it using Premiere and Dynamic Link After Effects compositions. The only way I’ve found to get it into Resolve (especially considering the number of AE comps I would have to deal with) is to export it as a DPX sequence.
    I’ve got the DPX sequence out using the Over Range preset in Premiere, and I’m trying to figure out what kind of gamma curve or LUT I should use, and where to set it (in the track settings, by right clicking the clip, or in the project settings?) Do I need a display LUT? I’d appreciate both a specific walk-through, or a link to one.
    DPX output settings:
    Rendered black point: 0
    Rendered white point: 1
    1-bit black point: 95
    10-bit white point: 685
    Gamma: 1.7
    Highlight rolloff: 0
    Logarithmic conversion is checked.
    Michael Morgenstern replied 12 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
