Activity Forums DaVinci Resolve R3D decode settings in S3D project
  • R3D decode settings in S3D project
    Posted by Eric Denis on December 5, 2012 at 8:12 pm
    On 9.0.4, every time I try to change decode settings from project to clip once a timeline has been set stereoscopic 3D, Resolve crashes… I found a round trip; unassign timeline from stereoscopic 3D, save project, change settings and then re-assign stereoscopic 3D. But please BMD FIX THIS!!!
    Eric
    Eric Denis replied 13 years, 8 months ago 3 Members · 3 Replies
  • Peter Chamberlain
    December 5, 2012 at 11:59 pm
    Can you send your project (no images) and capture logs to the DaVincihelp (at) blackmagicdesign (dot) com support email?
  • Vivek Vedagiri
    December 7, 2012 at 2:02 am
    Hi Eric,
    A fix will be available in the next update. In the meanwhile, there is a simpler work around to avoid this issue.
    Simply switch to SOLO grading mode (by unchecking the ‘Link’ icon on the Stereo 3D tab), make any changes that you need to make in the camera RAW settings, and then switch back to GANG grading mode.
    Vivek Vedagiri
    Blackmagic Design
  • Eric Denis
    December 7, 2012 at 3:11 pm
    Hi Vivek,
    I confirm that your work around works.
    Thank you for the support!
    Eric
