Activity Forums DaVinci Resolve R3D Conform and Trim troubleshooting
  • R3D Conform and Trim troubleshooting
    Posted by Henry Thompson on February 19, 2021 at 11:10 pm
    Hi all,
    I am conforming some 90min+ sequences right now from Premiere 2019 to Resolve 16 and having a hard time just keeping resolve open long enough to get through a 20 minute reel. All of the media is R3D 5k or Cinema DNG.
    I’ve broken the sequences into 20-minute reels to hopefully lighten the load on the computer and network. All media is has been copied to a thunderbolt 3 100 TB G Raid Shuttle or is already on the target thunderbolt 3 Graid 20TB delivery drive.
    The project database is on a NAS server with a 1Gb connection and my renders are going to a Nexis partition.
    I am able to move through the sequences quick enough while conforming shots but inevitably at some point throughout the day the project will just fail hard. At that point, I have to use a recent project backup to move the timeline into a fresh project to continue working. Usually, my pace with conforming at this point drops to barely a crawl and the rest of the afternoon is spent trying to troubleshoot the project. Restarting help, leaving the computer overnight seems to help, but I have been doing this insane workflow for a few days now and my conforms are moving in fits and starts. I dread building a full show in resolve with this media and fear I might not be able to with what I have.
    I’ve also tried trimming my R3D using the media manager and RedcineX. Both have issues. Resolve’s media manager fails every time when trying to trim and it doesn’t give you any indication of where in the process it has failed. RedcineX will trim successfully but then my trimmed files rarely match my Resolve sequence when I link back up.
    So, I am at a loss as far as troubleshooting goes. I might end up having to do everything in really small pieces to prep it for color. Any and all suggestions are welcome!
    Henry
    Specs below
    MacPro 7,1
    8 Core Intel Xeon W
    3.5 ghz / 96 GB 2666 MHz DDR4
    AMD Radeon Pro W5700X 16 GB
    Resolve 16 Studio
    Premiere 2019 or 2020
    David Baud replied 5 years, 6 months ago 2 Members · 1 Reply
  • David Baud
    February 20, 2021 at 12:56 am
    I feel your pain. I have been there in the past but not recently. They are so many areas that could go wrong, that you need to be thorough to check things out.
    Also you did not specify what is your master timeline frame size and frame rate. 4K? HD?
    Let me give you a list, even so you may certainly have already check some of them:
    . I’d check your system config.
    . how fast is your RAID and Nexis partitions (transfer rate in MB/s)?
    . have you tried to move the Resolve database locally?
    . what is your GPU setting? I would set to Metal
    . how are you decoding the RED footage? I believe in 16, you can specify using your GPU.
    . how do you process RED footage in camera RAW? full res? for the conform I would switch to half res or lower to see if it helps. Same for DNGs
    . are you using any caching / optimizing media? which codec?
    Good luck
