Activity Forums Storage & Archiving R380 Build errors
  • R380 Build errors
    Posted by Jaime Aguirre on December 25, 2015 at 10:04 pm
    I’ve been trying to initialize a raid 5 setup with this card and I’m having lots of issues. It’s currently at 44% and random drives keep failing. When I restart the machine, the initializing continues until it fails again. It’s always about 10 minutes into it. I suspect it’s probably a heat issue but I’m not sure. Below is the tail end of the log. I have an old Proavio eb8ms with 7 1TB RE4 HDs. It’s an old setup but it still quite fast for what I need. Any help?
    Dec 25 20:47:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000638 0, Op: 0x28, LBA:0x3d0cee00
    Dec 25 20:47:23 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000632 0, Op: 0x28, LBA:0x3d0cee00
    Dec 25 20:47:54 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000638 0, Op: 0x28, LBA:0x3d0cef00
    Dec 25 20:47:59 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000632 0, Op: 0x28, LBA:0x3d0cef00
    Dec 25 20:48:30 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf000
    Dec 25 20:48:35 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf000
    Dec 25 20:49:06 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf100
    Dec 25 20:49:11 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf100
    Dec 25 20:49:42 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf200
    Dec 25 20:49:47 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf200
    Dec 25 20:49:47 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000632 0, Op: 0x28, LBA:0x3d0cee00
    Dec 25 20:49:47 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x03, ASC: 0x11, ASCQ: 0x00
    Dec 25 20:49:47 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:49:47 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 5 Retries
    Dec 25 20:49:47 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] May need to replace drive
    Dec 25 20:49:47 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000632 0, Op: 0x28, LBA:0x3d0cef00
    Dec 25 20:49:48 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:49:48 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 5 Retries
    Dec 25 20:49:48 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] May need to replace drive
    Dec 25 20:49:48 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf000
    Dec 25 20:49:48 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x03, ASC: 0x11, ASCQ: 0x00
    Dec 25 20:49:48 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf100
    Dec 25 20:49:49 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:49:49 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 5 Retries
    Dec 25 20:49:49 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] May need to replace drive
    Dec 25 20:49:49 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf200
    Dec 25 20:49:49 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x03, ASC: 0x11, ASCQ: 0x00
    Dec 25 20:50:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf300
    Dec 25 20:50:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000638 0, Op: 0x28, LBA:0x3d0cee00
    Dec 25 20:50:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x03, ASC: 0x11, ASCQ: 0x00
    Dec 25 20:50:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:50:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 5 Retries
    Dec 25 20:50:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] May need to replace drive
    Dec 25 20:50:18 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000638 0, Op: 0x28, LBA:0x3d0cef00
    Dec 25 20:50:23 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:50:23 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 5 Retries
    Dec 25 20:50:23 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] May need to replace drive
    Dec 25 20:50:23 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf000
    Dec 25 20:50:23 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x03, ASC: 0x11, ASCQ: 0x00
    Dec 25 20:50:23 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf100
    Dec 25 20:50:24 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:50:24 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 5 Retries
    Dec 25 20:50:24 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] May need to replace drive
    Dec 25 20:50:24 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf200
    Dec 25 20:50:24 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x03, ASC: 0x11, ASCQ: 0x00
    Dec 25 20:50:24 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000638 0, Op: 0x28, LBA:0x3d0cf300
    Dec 25 20:50:25 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:50:25 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 5 Retries
    Dec 25 20:50:25 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] May need to replace drive
    Dec 25 20:50:25 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf300
    Dec 25 20:50:25 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000632 0, Op: 0x28, LBA:0x3d0cf300
    Dec 25 20:50:25 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x03, ASC: 0x11, ASCQ: 0x00
    Dec 25 20:50:25 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 6 Retries
    Dec 25 20:50:53 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000638 0, Op: 0x2A, LBA:0x3d0cec00
    Dec 25 20:50:53 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000638 0, Op: 0x2A, LBA:0x3d0cec00
    Dec 25 20:50:53 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x0B, ASC: 0x00, ASCQ: 0x00
    Dec 25 20:50:53 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:50:53 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 6 Retries
    Dec 25 20:50:53 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Retry the operation
    Dec 25 20:50:59 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Device 50:01:08:60:00:00:06:32 (LUN 0) status changed from OK to Faulted.
    Dec 25 20:50:59 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Device 50:01:08:60:00:00:06:33 (LUN 0) status changed from OK to Faulted.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Device 50:01:08:60:00:00:06:34 (LUN 0) status changed from OK to Faulted.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Device 50:01:08:60:00:00:06:35 (LUN 0) status changed from OK to Faulted.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Device 50:01:08:60:00:00:06:37 (LUN 0) status changed from OK to Faulted.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Device 50:01:08:60:00:00:06:38 (LUN 0) status changed from OK to Faulted.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” status changed: Online -> Degraded.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 0 operation changed – (Type: (Express) Initializing, Status: Faulted).
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 1 operation changed – (Type: (Express) Initializing, Status: Faulted).
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 2 operation changed – (Type: (Express) Initializing, Status: Faulted).
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 3 operation changed – (Type: (Express) Initializing, Status: Faulted).
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 4 operation changed – (Type: (Express) Initializing, Status: Faulted).
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 5 status changed: Online -> Faulted.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 5 operation changed – (Type: (Express) Initializing, Status: Faulted).
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] RAID Group state now Degraded: Monkey.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Timeout on 5001086000000632 0, Op: 0x2A, LBA:0x3d0ceb00
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Error on 5001086000000632 0, Op: 0x2A, LBA:0x3d0ceb00
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] SenseKey: 0x0B, ASC: 0x00, ASCQ: 0x00
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] State: 0x04, SState: 0x16, Code: 0x19
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] after 7 Retries
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] Retry the operation
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” status changed: Degraded -> Offline.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] RAID Group “Monkey” member 0 status changed: Online -> Faulted.
    Dec 25 20:51:00 MONKEY.local attocfgd[115]: [CRIT] [ExpressSAS R380,50:01:08:60:00:00:06:21] [FW] RAID Group state now Offline: Monkey.
    Dec 25 21:33:21 MONKEY.local attocfgd[108]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Failed to retrieve the number of VDA temperature sensors – VDA status 0x1
    Dec 25 21:38:29 MONKEY.local attocfgd[111]: [WARN] [ExpressSAS R380,50:01:08:60:00:00:06:21] [CT] Failed to retrieve the number of VDA temperature sensors – VDA status 0x1
    Jaime
    Bob Zelin replied 10 years, 8 months ago 2 Members · 6 Replies
  • Bob Zelin
    December 27, 2015 at 6:04 pm
    what OS are you running ?
    What driver on your R380
    what flash on your R380
    use ATTO Configuration Tool to tell me this info.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Jaime Aguirre
    December 27, 2015 at 7:38 pm
    Hi Bob. Thanks for replying. Here’s the info:
    OS: Mac OSX 10.8.5 Mountain Lion
    Driver: 3.85. Build date Sep 22 2011
    Flash: May 21, 2002. This is the latest.
    Atto Config tool: 3.38
    http://www.FlamingJaime.com
    JaimeFlameArtist@gmail.com
  • Bob Zelin
    December 28, 2015 at 1:17 pm
    Hi Jamie –
    everything you are running is old for the R380.
    Go to the support page at https://www.attotech.com
    Download V4.01 driver for the R380
    download 2012_05_21 firmware for the R380
    use the ATTO Config Tool V4.22 to flash the card (make sure your drives are disconnected when you do this).
    Reboot
    I bet everything starts to work.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Jaime Aguirre
    December 28, 2015 at 2:10 pm
    Hi Bob. Thanks again for your reply. I will give that a go in a a few minutes and let ya know what happens. cheers!
  • Jaime Aguirre
    December 29, 2015 at 2:17 pm
    Sorry for the late response. I was trying different things… I updated everything as per your instructions. I’m still having the same issues… Yesterday, I tried creating a raid 5 with 7 disks and it failed about 5% into it. It was giving me a disk error so I removed that disk, deleted the group, “cleaned” the disks (not sure if it’s necessary), and I tried creating another one with 6 disks. Failed again but went a little bit further. So I continued to do this. When I got to 3 drives, the initializing process actually finished. I opened up black magic disk speed test and ran it. About 4 minutes into it, I got a degraded drive then faulted. I’m not sure what to do at this point. Could it be the Proavio? SAS Cables? Could other apps/drivers be causing conflicts? What tests can I run to try and determine what exactly is going on? Not sure how to begin troubleshooting this. Maybe I can try using only one cable to see if it’ll fail? I just don’t know. I tried creating the raid groups both in Atto Config Tool and in the Bios. Both gave me the same results.
  • Bob Zelin
    December 29, 2015 at 4:46 pm
    emailed you privately.
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
