Activity › Forums › Maxon Cinema 4D › R15 not exporting position data to AE CC
  • R15 not exporting position data to AE CC
    Posted by Guy Slator on October 10, 2013 at 2:42 pm
    I’ve been trying to extract scene data from a C4D file created in R15 with cineware in AE CC, but the items that have object buffers on them for position data are not generating keyframes in AE for the movements, they are just fixed in the initial position.
    One of the objects is a screen on a computer which is grouped under a null with the rest of the parts. This in turn is under a fracture with a plain effector attached which is driving the movement.
    I’ve done similar things with R14 in the past and have checked everything is set up correctly. I also loaded a file created in R14 which had a similar set up and it generated the keyframes, I then copied that file and saved it in R15 and tried that in AE and it didn’t generate the keyframes.
    I was wondering if there is something different in R15 that would require an extra step or something like that or if it is a bug. Was wondering if anyone might be able to generate the same issue.
    Guy Slator replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
