Activity › Forums › Maxon Cinema 4D › R14 Keyframes have changed…
  • R14 Keyframes have changed…
    Posted by Evan Seitz on June 19, 2013 at 6:22 pm
    Hey guys – I’m not sure what technique to even call this, but I used to be able to take a cube (for example), keyframe it at rotation 0, go forward and keyframe it 180 degrees, and then go forward again and simply duplicate the second keyframe. This created an effect where the cube spun around a little past 180 and then bounced back into position.
    However, in R14, this effect is no longer working for me – how can I get it back?
    Evan Seitz replied 13 years, 3 months ago 2 Members · 2 Replies
  • Brian Jones
    June 19, 2013 at 7:33 pm
    they stopped that (because it is a problem most of the time) – in the timeline click on that second, middle, keyframe and uncheck Clamp in the Key Properties
  • Evan Seitz
    June 20, 2013 at 2:01 pm
    Perfection – thanks so much!
