Activity Forums Maxon Cinema 4D R13 License Server
  • R13 License Server
    Posted by Jonathan Abrams on November 1, 2013 at 5:12 pm
    Hello,
    I have a single license for Studio R13 that I may need to use between two computers (not simultaneous). Does the License Server app work with Studio R13? Do I have to upgrade to Studio R15 to use the License Server app for authorization?
    Thanks for reading!
    Jonathan S. Abrams, CEA, CEV, CBNT
    Apple Certified – Technical Coordinator (v10.5) Support Professional (v10.6 and v10.7)
    Vice-Chairman, NY section, AES
    Jack Chavez replied 12 years, 10 months ago 2 Members · 1 Reply
  • Jack Chavez
    November 9, 2013 at 1:30 am
    Unless things have changed, if you have the MSA, the EULA restriction on the number of machines that Cinema can be installed on is eased to permit 2 full installations, but it still only allows you to use one at a time.
    Not sure about whether the license server version has to match the release version of C4D. I don’t see why it should but then again…
