Activity › Forums › Adobe Premiere Pro › R128 Audio Standard Loudness metering
  • R128 Audio Standard Loudness metering
    Posted by Geoff Vane on February 7, 2012 at 6:11 pm
    Is there a plugin for R128 Audio Standard Loudness metering that actually works within Premiere CS5? The one I found AC-R128 crashes.
    New European regulations forbid any TV audio with loudness energy above -23 LUFS (0 LU). This can NOT be measured merely by investigating levels and compression; it’s a time vs energy metering which must be performed by a special algorithm.
    Angelo Lorenzo replied 14 years, 7 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    February 8, 2012 at 8:48 am
    None that I know of. I use a double check using Audio Leak on Mac https://www.channld.com/audioleak/ and also by sending audio through Adobe Audition and EQing it with an A-Weighted FFT filter and looking at the mean power reading over time.
