Activity Forums Blackmagic Design R-Y into DL Extreme seems to have died??? PLEASE HELP!
  • R-Y into DL Extreme seems to have died??? PLEASE HELP!
    Posted by Peter on June 23, 2005 at 3:37 pm
    Going component in from beta my “R-Y in” has stopped working. I’m getting blue/green color bars on input. Monitoring the deck via s-video to NTSC monitor shows that the deck itself is fine.
    I’m on OS 10.3.7 / 4.7.1 drivers which have been fine more or less for the past 8 months. I’d rather not update OS and drivers as I’m in the middle of a few projects but will if that’ll cure this problem.
    I’ve unconnected/reconnected all cables and restarted the computer to no avail. Is there anything else I should try?
    Thanks!!!!
    Peter replied 21 years, 2 months ago 1 Member · 1 Reply
  • Peter
    June 23, 2005 at 5:17 pm
    I shut down, unconnected/reconnected the MAIN CABLE from the card, restarted, and everything is working now. Must
