Activity Forums Apple Final Cut Pro Legacy Quicktimes I’m exporting are dual mono- need stereo
  • Quicktimes I’m exporting are dual mono- need stereo
    Posted by Lisa Olshanski on May 6, 2015 at 10:29 pm
    Okay. I’ve read the manual and I believe everything I can set to Stereo is set to stereo (see screen grabs below) but my Quicktimes that I export from FCP with current settings are coming out dual mono. Why? And how can I get them to come out with a Stereo mix without having to do QT conversion or go through compressor? My only audio tracks is a stereo mix directly from the audio engineer. Thanks in advance for any help!
    MacBook Pro- Mac OS ver. 10.9.3- Processor 2.3GHz- 16GB memory
    Final Cut 7
    Adobe Premiere CC
    Shane Ross replied 11 years, 4 months ago 4 Members · 6 Replies
  • Michael Gissing
    May 6, 2015 at 11:44 pm
    Did you check the panning in the timeline?
  • Lisa Olshanski
    May 6, 2015 at 11:48 pm
    When i double click on the clip it is says -1 in the source window. That’s correct right?
    Final Cut 7
    Adobe Premiere CC
  • Shane Ross
    May 7, 2015 at 12:05 am
    Everything says stereo…even the Quicktime information…so why do you think it’s dual mono?
    Shane
    Little Frog Post
  • Lisa Olshanski
    May 7, 2015 at 1:03 am
    Because the place that’s trafficking the spots told me. They asked me to fix them.
    Final Cut 7
    Adobe Premiere CC
  • Massimo Alberto croce
    May 7, 2015 at 12:05 pm
    Two thing, first of all, you need to discover if the file from sound engineer is a real steep or dual mono (use a correlation meter to discover it). Second, if the file is real stereo, you need to pan pot ch1 to left and ch2 to right.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Shane Ross
    May 7, 2015 at 1:55 pm
    If they say it’s dual mono, then the files you got back from the audio engineer might be dual mono. Yeah, you’ll have to have that checked.
    Shane
    Little Frog Post
