Activity Forums Apple Final Cut Pro Legacy Quicktimes appearing in Finder as Documents
  • Quicktimes appearing in Finder as Documents
    Posted by Jon Felix on February 3, 2010 at 4:47 pm
    I have a mysterious problem, I’ve never seen before.
    Some HDV footage was captured for me (on another system) and brought to our suite. All the Quicktimes in the Capture Scratch folder appear as simple Documents in the finder, and FCP will not recognize them (“File Error…”). Uh oh .. I thought.
    YET – the files are the right sizes (many gigs) and WILL open up in Quicktime (both 7 and 10) and play just fine.
    The Get Info about the file suggests that it is a text document and defaults to wanting text editor to open it with (although by default – as I said – QT opens them). I tried changing this to FCP but FCP still does not recognize the file.
    I found that I can use SAVE AS in Quicktime 7 to save a new Quicktime – which then DOES open in FCP, but since I have hundreds of files, and can only do this one at a time – this is not a viable solution.
    So I tried Compressor – thinking that I could batch convert the files – but Compressor does not recognize the original files either.
    FCS3 and SL (both systems).
    Any ideas most gratefully received ….
    Jon Felix
    DIGIT POST
    Marin County, California
    Jon Felix replied 16 years, 7 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    February 3, 2010 at 5:57 pm
    Try MPEG Streamclip for a batch conversion. google it, it’s free.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jeremy Garchow
    February 3, 2010 at 9:55 pm
    Use Automator to add a .mov extension.
    Jeremy
  • Jon Felix
    February 3, 2010 at 10:55 pm
    … Dumb! I shoulda thought of that. That worked.
    Thanks Jeremy. (And to you Jerry for your good suggestion too).
    Jon Felix
    DIGIT POST
