Activity › Forums › Sony Cameras › QuickTime Won’t Play XDCam EX Footage After ProApps Codec “Update”
Jon Schwartz replied 12 years, 6 months ago 8 Members · 21 Replies
Ian Cook
November 7, 2013 at 6:05 pmFor some reason my posts keep disappearing… 3rd attempt
The issue is that the recent ProApps update broke the QT decoder for users under Snow Leopard. Replacing the QT library folder with an older one or reverting to a backup taken before the update will fix the issue as you are then using an older version of the Apple codec. No codecs are installed with any of the Sony plugins. We are talking with Apple about this now and I hope to have an update soon
Djordje Cenic
November 19, 2013 at 8:32 pmhi,
is there any news? are you going to be able to fix the problem?
thanks
greetings from austria -
Ian Cook
November 19, 2013 at 8:38 pmIt’s an Apple issue, we are working with them on a fix. In the meantime if you can revert the system or just the Library/QuickTime folder back to a pre-upgrade state the codecs will come back.
Djordje Cenic
November 20, 2013 at 8:35 amhi,
now i managed to organize an older version of snow leopard and exchanged the messed up library/quicktime folder. it works.
thanks for posting and helping!
djordje
Djordje Cenic
November 23, 2013 at 5:09 pmHi,
there are two updates now:
1) Quick Time-Codecs for ProApps 1.0.3
2) Pro Applications Update 2010-02 1.0Are they the safe patch now?
Grateful for every information.
Thank you.Djordje
David Wooten
January 14, 2014 at 2:04 pmWe experienced the same problem. If you have a machine that did not get updated, you can copy the QuickTime elements from the Library folder from the un-updated machine to the affected machine and your pictures will return. We feel this is easier and faster than a re-install, if you have access to a machine with a Library folder from ProApps 1.0.
Michael Moser
January 26, 2014 at 12:28 amHi Ian-
Will the new (as of 1/25/14) ProApps update break XDCam on Snow Leopard (OS 10.6.8)?
Mike -
Ian Cook
January 27, 2014 at 4:23 pmI tested over the weekend and it did not break my Snow Leopard system. Still waiting on a confirmation that this version fixes the issue with update 1.0.3. Curious to see what other users report.
Michael Moser
January 28, 2014 at 6:57 pmI’ve updated the two Snow Leopard computers with no ill effects (….so far). All XDCam EX footage plays just fine.
Thanks Ian.
-Mike
