Activity Forums Adobe After Effects Quicktime will only render to external device/drive (AE 5.5/Media Encoder 5.5)
  • Quicktime will only render to external device/drive (AE 5.5/Media Encoder 5.5)
    Posted by Georgina Lord on May 14, 2012 at 10:55 pm
    For some reason, when rendering out from After Effects (CS5.5) if I choose to export as a Quicktime .mov file the render fails almost immediately. I’ve tried rendering the file with Media Encoder but get the same result. If I render the file using any other format (.mp4, avi, wmv etc) it works flawlessly.
    The only way I can render using Quicktime is to use an external device (such as a USB stick) as the target device. If I do that, it works perfectly, but immediately fails on my local hard drive. I’ve tried to render to the root or a drive, different partitions, and into folders, but no luck. So exporting as QT works, BUT only if I export to an external device.
    Has anyone else experienced this problem, and is there a solution?
    Bret Williams replied 14 years, 4 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    May 15, 2012 at 2:36 am
    This is indeed strange. I would check to ensure that QT is updated and if that doesn’t fix the issue then trash AE’s prefs.
    Good Luck
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Bret Williams
    May 16, 2012 at 6:38 am
    Are you on Lion? OSX Lion doesn’t permit (even admin) to write to the root of system drive. To create a folder there you have to enter an admin password. But I don’t think AE would be able to write there.
    You can override the permissions in the get info panel by adding yourself. But probably better just to write to a folder in your user folder or the desktop or an external drive of course.
