Activity › Forums › Apple OS X › Quicktime to wmv file: “Failed- a file or directory could not be found (-43)”
  • Quicktime to wmv file: “Failed- a file or directory could not be found (-43)”
    Posted by Tad Newberry on March 3, 2011 at 8:06 pm
    i did some web-searching for QT error (-43), but it only seemed to yield filename length issues, which i tried to no avail. i had been able to open a QT movie, then export to wmv with no problems until lately, now i get, “”Failed- a file or directory could not be found (-43)”. Any ideas? Time to re-install QT Pro? Other codec conversions still seem to work fine out of QT Pro, just not wmv’s…
    thanks for helping out a bonehead!
    __________________________
    FCS3
    2.66 GHz Quad-Core Mac Pro
    6GB RAM
    NVIDIA GeForce GT 120
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Tad Newberry replied 15 years, 6 months ago 2 Members · 4 Replies
  • Jeff Greenberg
    March 4, 2011 at 1:44 pm
    What’s the third party tool that you’re using for WMVs? QuickTime pro doesn’t do it out of the box. Flip4Mac? Have you seen if they’ve updated their software since you installed it?
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Tad Newberry
    March 5, 2011 at 1:39 am
    ya, it’s updated…just downloaded and installed update again. still same error…and no wmv option out of FCP “Share”…
    FCS3
    6GB RAM
  • Jeff Greenberg
    March 5, 2011 at 2:45 am
    Tad,
    So, if you’ll forgive that I’m hunting around and be patient, I’ll keep trying.
    Hmm, Ok, so some quick googling leads me to believe that the problem is the “WHERE” for the share – can you change the location?
    Best,
    Jeff G
    Best,
    Jeff G
  • Tad Newberry
    March 5, 2011 at 3:37 am
    hmmmm, mr. smarty pants…i changed destination drives and it worked! And, “forgive you” for hunting around for an answer for ME??? no, i THANK you immensely for spending your time on it. Thanks a bunch!
    FCS3
    6GB RAM
