Activity › Forums › Adobe After Effects › Quicktime to .MXF ??
Posted by Jason Richards on July 22, 2009 at 2:38 pmOur newsroom uses grass valley news edit which is .MXF file format. What can I use to convert quicktime into .MXF ?
Jason Richards replied 17 years, 2 months ago 2 Members · 2 Replies -
Kevin Camp
July 22, 2009 at 3:34 pmif the gv systems have quicktime installed on them, then i’d bet that they can import an mov and they’ll do the conversion to an mxf container. you’ll just want to make sure you create an mov with a standard qt component (codec), like lossless animation or photo-jpeg, rather than prores or something that would come with an apple pro app.
it’s the way i work with avids, which also works with the mxf file structure.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Jason Richards
July 22, 2009 at 3:47 pmwell our engineers are technically challenged..lol, but seriously. I’m actually a designer doing some research on this topic because they tell me they can’t convert them with the edit system because they are on like version 1. It runs on a PC. Right now we use Flip Factory for the conversion, but I find it hard to believe they can’t import those quicktimes straight into the edit system and let it do the conversion. I’m not that all impressed with flip factory so I’m trying to cut out the middle man if you know what i mean.
