Activity Forums VEGAS Pro QuickTime to MPEG2 for DVD
  • QuickTime to MPEG2 for DVD
    Posted by Russell Robertson on April 18, 2005 at 2:01 pm
    Hi Folks,
    I was asked to take a collection of 10x QuickTime clips and put them onto a DVD for playback on a DVD player. What method would result in the highest quality playback? Do I have to be concerned with interlacing? The originals are 320×240
    Laszlo Kovacs replied 21 years, 4 months ago 2 Members · 3 Replies
  • Laszlo Kovacs
    April 18, 2005 at 2:54 pm
    Hi there,
    Look for quicktime alternative
    https://www.free-codecs.com/download/QuickTime_Alternative.htm
    (probably you’ll get lot more result on searching google.)
    This installs a directshow codec, so vegas can use mov files
    just like any avi, assuming the codec is installed for it.
    Upsize the picture to 720*576 (PAL) or 720*480 (NTSC)
    don’t worry about interlacing or anything, vegas does
    the rest.
    Just render out to DVD compliant mpeg2.
    Hope I could help.
    By(t)e
    Laca
  • Russell Robertson
    April 18, 2005 at 4:29 pm
    Laszlo,
    koszonom a tanacsot…udvozlet New Jersey-bol…
    Do you think that perhaps somthing like Super Sampling would help get the best quality from the QuickTime original? Any color correction suggestions?
    Russell
  • Laszlo Kovacs
    April 18, 2005 at 7:06 pm
    Hi Russel,
    The quality is already determined by the low
    resolution and low bitrate (high compression)
    of quicktime mov.
    There will be no real quality enhancement rendering
    it to a higher resolution, however you could blur it
    to reduce it’s blockyness.
    Make some test renders (and/or burns to RW discs)
    to see if you can achieve some subjective enhancement.
    Colorcorrect it if you’re unsatisfied with it’s colorspace.
    :))) szivesen, udvozlet Budapestrol…
    mailto:kovacslt@fw.hu
    https://www.kovacslt.fw.hu
    By(t)e
    Laca
